Oversized tires
- dizzy
Oversized tires
If putting on 37-12.5-17 mtr Kevlar tires on an H2. Would you have any negative side effects like messing up ABS or messing up your tranny shift points .I know this would go for all 37-12.5 tires and I know the speedo will be off by about 5kmph.Also the H2 does not have tire pressure monitors to worry about like the H3.
Re: Oversized tires
No TP monitors to worry about and no issues with ABS or Tranny, just be sure to disconnect your battery, both pos and neg and then touch them together to reset the pcm and then go for a long drive, the computer will relearn with the new tires! Not perfect but better than nothing, the ideal would be a reflash of the PCM!
- dizzy
Re: Oversized tires
Thanks for that info Kev. So after disconnect you just touch the pos and neg cables together for what, a couple seconds? Will the computer try and relearn speedometer as well? Thanks. Doug
- dizzy
Re: Oversized tires
Best price so far for the Goodyear MTR Kevlar is $360 ea. Installed and ballanced at Bramalea Tire.
Re: Oversized tires
that is a great price ..in the US.... 315 unit plus transport....so that means that is a super price buy them bro!!!!!!!!!! <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
Re: Oversized tires
[quote author=dizzy link=topic=962.msg7074#msg7074 date=1239040666]
i wonder if we both buy if they will give us a better deal???
- edawh3
Re: Oversized tires
Kevin: I just put 35" BF Goodrich All Terrains on my H3 so would it b e necessary to reset the PCM like in the H2 or would the H3 setup even be the same.
- Sugarphreak
Re: Oversized tires
Would also like to know this;
Also, does anybody know roughly what the tolerances are for an H3 when it comes to offset VS tire widths? Maybe also how much negitive offset can you run on a rim while still keeping the tire under the fender (with tire widths)
Re: Oversized tires
[quote author=edawh3 link=topic=962.msg11318#msg11318 date=1255822792]
It will be the same but onething I have noticed is that the TPMS gets cranky and will send false alarms of low TP when the pressures are fine. But overall the same procedure with the battery should eliminate most problems with the computer. To have no problems you would need to reflash your PCM with the new tire size to make the TPMS happy!
Re: Oversized tires
[quote author=Sugarphreak link=topic=962.msg11349#msg11349 date=1256051945]
From experience, the stock rims, with the stock offset, with 35x12.50 tires will just clear the edge of the fenders, any different offset than stock will put the tires way out and require a lift to prevent rubbing on the rear of the front fenders while turning. The 35x12.50 will fit nicely into the wheelwell on all H3s with a torsion bar lift with little to no rubbing, unless the tire has sidebiters!
Hope this helps!
Hope this helps!
